Brake lights dont work??
Old Oct 2, 2007 | 08:53 PM
Jose's Avatar
Default RE: Brake lights dont work??
the fuses can fool you if they are the ones with a paper inside, so try replacing the fuse even if it looks good.
I take it you checked the Stop Bulbs? (the upper ones).
Next step is to remove the lenses and then eachtail lamp assembly to check the large Plug connecting the assembly to the wire harness. Take the plug with both hands and "twist" each half in a different direction while pushing them inwards, to make sure there is good contact everywhere. Also check the rear contacts in the tail lamp assembly.
Next check is the wire connectionsin the Brake Switchlocated under the Brake Pedal. (because you never know...)
My question is: Do the Driving lights go On ? (the Red, normal, "driving" light).
let us know what happens.
Jose
MJ'S Jag
Nov 10, 2022 08:14 AM
Stigram
Jun 17, 2022 12:05 PM
johnnie ryall
Oct 19, 2015 09:44 PM
jdzubas
Oct 4, 2015 09:14 AM
tonydbaker
Aug 30, 2015 11:02 PM
