A/C wont take a charge 92 Vanden Plas
Old Jul 31, 2018 | 04:54 PM
JansJags's Avatar
Default A/C wont take a charge 92 Vanden Plas
I have evacuated the system. It will take the first can because its pumped down. The compressor is running. But the system wont take more and the pressures are the same on the low and high side. I an filling through the low side as is necessary. I have never had this situation before. Shop manual suggests leakage in the compressor. Could it be so?
Old Aug 1, 2018 | 06:46 AM
icsamerica's Avatar
Remove the expansion valve and check it for clogs. Chances are the accumulator failed and desicant is clogging expansion.
hunterpedigo
Jun 21, 2017 08:59 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
hunterpedigo
Oct 29, 2015 05:31 PM
