Carb leaking gas
Old Jun 1, 2014 | 11:21 PM
smgdata's Avatar
Default Carb leaking gas
On my xjc today, i had to be towed home the rear carb was leaking gas out the front.
When i took off the whole intake assembly, it looks like it was coming out the two holes on the top to the right and left. whats also odd when i lift the piston what i see is what i could call mist wall of gas going onto the engine.
i havnt had the chance yet to really get to know this whole car and as i have said before im "carb dumb"
s\
Old Jun 2, 2014 | 04:26 PM
Fraser Mitchell's Avatar
Sounds like the fuel chamber valve is leaking or the float is not floating ! These floats can leak after many years use, so don't close the valve properly. Are they SUs or Strombergs ? I can still remember many years ago stripping a carb down and shaking the float to see if it had any fuel inside it. It had !!
Old Jun 3, 2014 | 12:45 AM
smgdata's Avatar
Strombergs.
I wasfeeling around it looks like the choke mechanism was loose, tightened it up so far its not leaking like it was.
Russ Graber
Feb 23, 2019 11:59 AM
Papelione
Sep 21, 2015 06:13 PM
rusty37
Sep 18, 2015 10:03 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
