Coil wires
Old Sep 19, 2024 | 06:16 PM
jordanmc's Avatar
Default Coil wires
Cleaning up some wiring. I don’t believe I ever had this connected. Should I?
3 wires in the harness 2 are connected. This one is not. 1979 Jaguar XJ6 series 2 with fuel injection.
Old Oct 1, 2024 | 09:30 PM
xjtom's Avatar
there are 2 ignition systems for the S2 efi,...the white/slate/blue wire you refer to is for a standard system, the wire goes to tacho from ignition coil, if your tacho is working then someone has made an alternative fitting... i have complete schematics for early models> https://www.jaguar-wiring-schematics.info/index.htm
roberlar
Apr 1, 2025 03:49 AM
brinny
Oct 2, 2023 01:43 AM
rckunze5
Apr 23, 2023 05:08 PM
marzipan
Jul 31, 2022 06:30 PM
PerErs
May 30, 2022 01:55 PM
