Coil wiring.
Old Oct 1, 2023 | 11:45 AM
brinny's Avatar
Default Coil wiring.
Hi all, having a bit of trouble with the wiring on my new coil. This is going on a series 2, 4.2. The new coil came with a ballast resistor attached to it and a jumper wire from the + on the resistor to the + on the coil. My old set up didn't have this. Also the old ballast resistor isn't marked + or -. Any assistance greatly appreciated.
Old Oct 1, 2023 | 02:04 PM
brinny's Avatar
Further to this, after studying the wiring diagram I don't think I need the additional jumper wire that came with the new coil. Can anyone confirm I can just remove it?
Old Oct 1, 2023 | 04:48 PM
xjtom's Avatar
below is a pic of standard ignition, ballast resistor can be connected either way......
Old Oct 2, 2023 | 12:51 AM
brinny's Avatar
thanks Tom. It was the little black jumper wire that confused me. Looks like I can just remove it.
Old Oct 2, 2023 | 01:43 AM
xjtom's Avatar
now i see what you were talking about, the maker would have fitted that to be certain it would be fitted correctly
.i'd be moving that ballast off the coil to cut down on heat
Mjoseph420
Jan 16, 2015 09:16 AM
beegee22
Jan 19, 2014 05:23 AM
JaguXJR
Dec 5, 2012 07:08 AM
Jashuar85
Aug 25, 2011 11:23 AM
wnlewis
Apr 2, 2009 10:17 PM
