Dash Harness
Old Mar 7, 2016 | 08:59 AM
asaphelps's Avatar
Default Dash Harness
Hi all,
how much difficult it is to replace the entire dash harness? Has to be taken apart everything or only the top dash and center console?
Thank you!
Asa
Old Mar 7, 2016 | 04:56 PM
Fraser Mitchell's Avatar
Can you tell us which car you have, because the later cars had firewall plugs and sockets so the loom wasn't continuous from dash to engine compartment. Do bear in mind that some harnesses that terminate behind the dash could be quite lengthy and extend a long way into the rear of the car.
Old Mar 7, 2016 | 04:58 PM
asaphelps's Avatar
Of course, I'm sorry I did not mentioned before: it is a 1973 Series 1
Old Mar 8, 2016 | 04:23 PM
Japawels's Avatar
If it's a series 1, removing just the top dash might not be enough as I recall. I suggest removing the panels as it would be much easier to get to all of the plugs.
Old Mar 9, 2016 | 09:06 PM
davidboger's Avatar
You pretty much have to remove everything to get the wiring harness out.. So plan on the dash pad, dash, all the underscuttle casings, The lower A post covers, may as well drop the steering wheel... It's a mangled up mess... but remember, the wiring harness likely went in the car first on assembly, so it will come out last...
FWIW... I have a couple of the Series 1 harnesses on hand...
David
shop.EverydayXJ.com
SRL1990
Apr 19, 2016 01:26 PM
klfong
Mar 6, 2016 12:08 AM
tedwone
Mar 5, 2016 07:25 AM
dogsoup
Mar 4, 2016 07:33 AM
OMGPirate
Mar 1, 2016 06:38 PM
