Diff Swap
Old Apr 30, 2012 | 06:08 AM
Mopoor's Avatar
Default Diff Swap
I have a 71 XJ6 with a Supra 5 speed gear box in it. It was an automatic originally so has the auto diff 3.31:1 (?) which is not ideal for highway cruising. Good for grunt off the line but revs are a bit high when cruising. I have the opportunity to purchase a 2.88:1 Powerlock diff out of a V12 XJS. Couple of questions. Is it a straight swap; old one out new one in? Can it be done without dropping the whole rear end out? Any thoughts would be appreciated. Thanks
Old Apr 30, 2012 | 07:36 AM
Doug's Avatar
First, the entire rear end must come out, yes.
I *think it'll be a direct bolt-in swap but there are a couple of things......
Some of the mid-80s XJSs used a Dana differental....easily identified by lack of a drain plug at the bottom. If this is what you have you'll need matching brake rotors to go with it.
If you had a Ser III XJ6 I *know* it would be a direct swap but I'm not familiar enough with Ser I cars to know if there are any detail differences that might be a problem. I doubt it, but I'd wait for other others to chime in
Old May 4, 2012 | 04:40 PM
Fraser Mitchell's Avatar
I would say you will be OK, but what year was the XJS the replacement diff came off ?
Old May 7, 2012 | 01:57 AM
Mopoor's Avatar
Thanks Fraser
85 or 86 I think
Old May 7, 2012 | 07:00 AM
AFAIK, nothing changed much on the rear suspension until the brakes were moved outboard in the 90s. The XJS was a very low production levels car, so essentially used the XJ saloon suspension with different spring rates and diff ratios, although the front subframe was different, I think.
However, as Doug says, there may be more to it, depending on what manufacturer supplied the diff. Anyway, a pair of new discs won't break the bank if you need to fit them.
Newark Nj Gang
Oct 2, 2015 02:39 PM
millertic
Sep 30, 2015 08:11 PM
pnwrs2000
Sep 30, 2015 01:56 PM
Mark SF
Sep 28, 2015 01:51 PM
