Dim new headlight
Old Aug 4, 2014 | 11:30 AM
cmw's Avatar
cmw
Default Dim new headlight
1983 XJ6 4.2 I replaced the (2) low and (2) high beam headlights and the right outside head light is dim although new. Any thoughts?
Old Aug 4, 2014 | 11:59 AM
Civicalized's Avatar
I'd first start checking any and all ground wires that may affect that light. maybe came loose, undone, is corroded. That would be my guess, assuming the new light is ok.
Welcome to the forum by the way!
Old Aug 4, 2014 | 04:49 PM
Jose's Avatar
first try reinstalling the old lamp again to see if the new one is bad.
check the low beam fuse
Old Aug 5, 2014 | 10:43 AM
Darrenmb's Avatar
Veteran: Navy
X2 on a bad ground. One dim headlamp is 99% of the time a ground issue
Old Aug 5, 2014 | 11:08 AM
JagCad's Avatar
Ditto!!!
Ground!!!
Old Aug 6, 2014 | 12:59 AM
yarpos's Avatar
This is an interesting read if you want to go through the system and make sure everything is up to scratch.
Headlamp Circuit Checklist Series III XJ6
Old Apr 16, 2025 | 10:12 AM
Compound's Avatar
Old post, but frequent issue. Could you check the link for this?
Or could someone refer the above list?
Thanks!
Old Apr 16, 2025 | 10:15 AM
Compound's Avatar
There are three wires coming to headlamp, but all disappear inside. Where is the grounding point located?
Old Apr 16, 2025 | 10:27 PM
Doug's Avatar
You'll find the headlight grounds on either side of the radiator; on the forward face of bulkhead that the radiator sits in
Old Apr 17, 2025 | 02:40 AM
Compound's Avatar
Found them! Thank you for the quick reply!
hoodun
Nov 20, 2022 02:35 PM
Jaguar Forums Editor
Jaguar Press release
Sep 30, 2015 03:08 PM
Sep 28, 2015 05:18 PM
kevinl
Sep 24, 2015 08:25 PM
