A good l'fashioned auto electrician
Old Jul 27, 2017 | 07:50 PM
Paulie63's Avatar
Default A good l'fashioned auto electrician
Can any one recommend a good auto electrician in the Colorado Springs area?
I tried the local Jaguar club and found no success.
Old Jul 28, 2017 | 12:38 AM
yarpos's Avatar
maybe posting in the regional section covering that location, might get more hits than the general XJ6 section?
Old Jul 28, 2017 | 08:37 AM
Doug's Avatar
What problem are you trying to fix? And what kind of car?
Old Jul 28, 2017 | 09:03 AM
JagCad's Avatar
Do they exist anymore? School chum, Roy had a summer job at one.
Oakes Auto Electric. Just behind Western Auto on Texas Street in El Paso.
But, by far their work was in starters and generators. Pre alternator days.
Roy replace the cumbersome Model A Ford generator with one designed for a Ford 8N or so tractor. Fit just right, no fabbing needed. More Amps.
Carl
Old Jul 28, 2017 | 03:41 PM
Paulie63's Avatar
Doug, I have a 76 xj12 with a short to the interior lights circuit.
Old Jul 28, 2017 | 04:07 PM
Jose's Avatar
that one is easy, the most likely culprit is one of the door jamb switches stuck open or closed. Spray WD40 at each switch plunger push it in and out 10 times each, see if that helps.
