hesitates/stumbles under load
Old Apr 25, 2009 | 05:22 PM
skanoski's Avatar
Default hesitates/stumbles under load
86 sovereign (xj6) - it was been running perfectly for a long time .. until now. It starts fine, idles normal, but when accelerating it hesitates and stumbles. If I hammer the gas, for instance, at 25mph, it seems like it slows down for a second or two, then sort of "catches", but not quite fully. Something is screwed. So far I've replaced the fuel filter, as it seemed like clogged filter symptoms -- no improvement.
anyone had a similar issue on the series III?
thanks in advance.
Old Apr 26, 2009 | 03:01 PM
Walter1982's Avatar
Yes, my 1982 Series 3 (4.2) also stumbles a bit. I did plugs, wires, cap and rotor, but still no improvement. I am now just used to it. I did buy a new coil, but havent swapped it out yet....
Old Apr 26, 2009 | 07:23 PM
skanoski's Avatar
I also have new plugs, wires, cap & rotor, air filter, fuel filter - so I can eliminate those. Mine is pretty bad and not something I can ignore. I'm going to look at the throttle tomorrow, maybe try to clean it or something.
Old Apr 27, 2009 | 09:28 AM
dave2's Avatar
Check for vacuum/air intake leaks around the afm. These pop off occasionally. Happened to me before.
Old Apr 27, 2009 | 01:08 PM
skanoski's Avatar
afm = air flow meter?
Old Apr 28, 2009 | 07:10 AM
dave2's Avatar
Sorry, yes AFM=Air Flow Meter.
A binding flap inside there can also cause issues.
Checked the fuel pressure yet? It could be marginal, not getting enough fuel when you drive harder requiring more fuel.
JaguarLover101
48
Jun 12, 2023 10:28 AM
Inspector
Oct 17, 2015 12:51 PM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
zoozth
Sep 29, 2015 07:28 AM
Vector
US Lower Atlantic
Sep 28, 2015 11:08 AM
