Hood hinge issues
Old Oct 13, 2010 | 11:36 AM
Mayne's Avatar
Default Hood hinge issues
Hi all,
In trying to help my Dad fix a hood alignment problem on hi 83 xj6, I discovered the drivers side hinge attachment point of the hood is kind of ripped out. The bolts will grab, be when the tension of closing the hood increase, the bolts pop out some and change the angle of the hood slightly. It looks to me like there's some rust on the hood riight at the mounting point. Is this common? Any suggestions for repair? Thanks,
Old Oct 13, 2010 | 02:11 PM
AristoCat's Avatar
get a tap & dye set.
Chase the threads with the proper size tap, if that doesn't work, move up to the next size and swap out to larger hardware.
Then there is the third option: weld the hole up, re-drill & tap new threads.
Old Oct 14, 2010 | 07:37 AM
Mayne's Avatar
Well, my first thought was that it was the threads also, so I cheated and forced in a slightly larger bolt (I know. . . but there's almost no room for a tap in that space). Anyway, I got the bolt in good and tight and figured I had solved it, then closed the hood and had the same problem.
I assuming what I'm threading into in the hood is a captured nut. What I actually think is happening is that the rusted sheet metal around the nut has actually torn out. I guess removing the hood is in our future. Thanks,
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Daim
Nov 28, 2016 09:28 AM
WinterJag
16
Oct 9, 2015 07:49 PM
redrover41
23
Sep 25, 2015 01:33 PM
