ignition assembly
Old Aug 1, 2012 | 07:44 PM
doghead08's Avatar
Default ignition assembly
does anyone know how do put it back together?
mine popped out and i couldnt get it back with the right resistance.
should there be resistance if the battery is not hooked up or will the key just turn with ease
Old Aug 1, 2012 | 08:35 PM
Doug's Avatar
Clarify please.
Are you talking about the ignition switch at the back of the key cylinder? It's held in place with a very tiny screw.
Or are you talking about the steering column lock that engages/disengages with the key?Never been there so I'm no help, sorry.
Old Aug 1, 2012 | 08:53 PM
doghead08's Avatar
the steering column lock. i need to know how to get the contraption (where i put the key in to start the car) back together. the back piece where the wires are connected popped off.
Old Aug 2, 2012 | 04:08 PM
doghead08's Avatar
Default fixed
i sodored the brown wire and figured out the right configuration that the center piece sits along with the spring distribution and bering placement..AFTER 8 hours
it was a battle but i persevered in the end. i found it odd that the back piece of the ignition didnt have something to hold it in there tight. if it did it probably broke off when i was fiddling with it.
eventually figured out that unless its secured nice and flush it wont work.
i cleaned up the wire mess from the previous owner. plenty of room and it looks so much cleaner.
still cant find where the purple and black wire plug into the horn????
Old Aug 2, 2012 | 07:31 PM
Doug's Avatar
On the right side of the steering column there's a brass "finger" thingy which goes into the column. The wire should attach there
Old Aug 2, 2012 | 07:58 PM
doghead08's Avatar
thanks doug....im goin to check now
Old Aug 2, 2012 | 08:12 PM
doghead08's Avatar
ill be damned...that was way to easy for me to have ever been able to figure out.
horn operational.gracias
tomkilner
Oct 9, 2015 07:10 AM
goges
Oct 5, 2015 04:53 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
millertic
Sep 30, 2015 08:11 PM
