Injectors vs Fuel Pump
Old Oct 3, 2018 | 05:18 PM
benji808's Avatar
Default Injectors vs Fuel Pump
Quick question: when the ecu decides to send a richer mix (i.e. AFM door is open), does it tell the injectors to spray more, or does it tell the pump to pump faster in order to force more gas through. In other words, does the pump have varying speeds based on need, or is the flow managed by a variable spray from the injector?
Thanks!
Old Oct 3, 2018 | 07:14 PM
Doug's Avatar
The ECU 'tells' the injectors to stay open longer when needed
The pump is constant speed. A fuel pressure regulator maintains correct pressure in the fuel rail by bleeding-off fuel, which is returned to the tanks
Old Oct 4, 2018 | 10:22 AM
JagCad's Avatar
Ditto:
Doug beat me to the response.
His probably better than mine would have been.
Carl
Roger95
XJ40 ( XJ81 )
Sep 18, 2018 09:15 AM
JayJagJay
Jul 18, 2017 05:59 PM
Masher02
Jan 11, 2016 04:35 PM
jimlombardi
May 7, 2012 04:59 AM
