jurid coupling
Old Aug 7, 2017 | 05:00 PM
peter J's Avatar
Default jurid coupling
Did series 1 xj6 cars incorporate a jurid coupling in their driveline? Don"t see one on mine and am wondering if this is giving me driveline vibration above 50 mph.
Old Aug 7, 2017 | 07:08 PM
Doug's Avatar
As far as I know Jaguar didn't begin using the Jurid couplings until the XJ40 came along. Not aware of any Series I-II-III using them.
Old Aug 7, 2017 | 07:20 PM
icsamerica's Avatar
No jurid coupling...known to me as a guibo. In any case vibrations typically are cuased by a notchy u-joints. Also check the center support. Basically you're gonna have to remove the shaft and perform a good inspection.
in rare cases... a balance weight can rust off or the shaft can be dinged or damaged in some other way.
Old Aug 7, 2017 | 07:56 PM
peter J's Avatar
thank you both! po did some driveline work and it might be misaligned.
