Need Pick-up for 82 XJ6
Old Jul 20, 2019 | 10:36 AM
Exodus82's Avatar
Default Need Pick-up for 82 XJ6
Hello All. I'm looking for a Distributor Pick-UP and ignition Amplifier module for my 82 XJ6 series III. Does anyone know where I can locate these at a reasonable price? good/used is fine. Autozone wants approximately $180.00 for the Pick-up???
Thanks.
Old Jul 20, 2019 | 08:36 PM
Yellow series3's Avatar
David at www.EverydayXJ.com
Old Jul 20, 2019 | 09:34 PM
David84XJ6's Avatar
SNG Barratt
Pick-Up and Base Plate Assembly
Product Code: AEU1500
Part Type: Standard
Pick up and base plate assembly with lead and black plastic molded plug. $90.06
This has new base for advance, (new/or use pick-up on old advance base will leave you unsure of advance accuracy or if ground is sketchy.)
I installed this and was satisfied.
Also found New AC Delco D1906 Professional Ignition Control Module on Amazon for $35, Don't waste your time on $8 knock-offs from China
Rgds
David
Don60
Aug 13, 2012 11:53 PM
baycliffpwds
Sep 26, 2010 11:57 PM
Clifsmith
26
Sep 14, 2009 02:32 PM
richnota
Sep 9, 2007 11:10 AM
