power window relay/fuse 85 xj6 help
Chaffed wire.
I talking about a wire carrying "+" voltage that is shorting out. Could be anywhere along the line between the breakers and the motors.
But before you go on a wild goose chase let's clarify a few things and perhaps narrow it down
Which side isn't working?
If you use a fuse instead of a breaker will it blow instantly as soon as the key is turned on? Or only if you operate the switches?
Passengers' side (US auto); uses the flat relays. I have tested the motors - they work; windows currently up. I have tested the switches - exchanging them with the driver's side - they work. I have replaced the circuit breaker (round thing) with a brand new one.
As I have owned this XJ6 for 24 years and an 86 XJ6 for 15 years and about 20 XK-Es over time - I am acquainted with Lucas' wiring and the peccadilloes of them.
Now..... when I put the relay back in, all it does is click. Have wanted to put the driver's side in but fear it may blow and then..... I did go out and purchase a 30 amp Corvette relay - upon installing and turning the key - smoke in the cockpit - coming from the switches....
So........ Many thanks Chuck
The window relay (singular) is round
The circuit breakers (two) are flat:
If clicking and smoke occur when you plug-in a circuit breaker...but without operating the window motors.... then you have a short circuit.
On the basis of "ya gotta start somewhere" I'd unplug all the switches and see if the clicking goes away. If it doesn't, then you have a problem upstream of the switches.
More later. I'm on my first cuppa coffee
Got it! The master switch is not flipped, and I checked the voltages.
Brown has around 13 all the time
White/pink has around 13 when key is on.
Black/ pink ground works.
But the double red/slate has no voltages key on/off. I also checked all four red/slates under the glove compartment going in and out of the (I guess 2 circuit breakers?).
The relays part connecting to red/slate, numbered 87, was also different color than the rest 86,85 etc., sort of like oxidized.
Any suggestions, I'm getting better at this with my new voltage meter lol.
Thank you in advance for your help
Assuming you have a left hand drive car the window relay is at the extreme right side of the dashboard, outboard of the glovebox.
A faulty old Lucas relay was my issue. A new Panasonic piece has replaced it. Windows all work now!
99xk8guy
Sep 29, 2025 10:51 PM
rusty37
Apr 5, 2020 07:40 PM
