Radio Line Fuse Location
Old May 17, 2015 | 12:51 PM
wildman's Avatar
Default Radio Line Fuse Location
I have a 1985 XJ6 and radio stopped working. I think there is an in line fuse but cannot find it.
Anyone know the location?
Old May 17, 2015 | 03:09 PM
Jose's Avatar
there are two fuses, they will be behind the driver's side floor vent console panel.
Remove the two screws holding the black plastic vent and pull the vent. Then pull the upholstered console panel towards the engine to release it.
Old May 17, 2015 | 03:21 PM
Doug's Avatar
If, by chance, you can't find 'em by the vents panel as Jose describes.....look down in the area just forward of the LH ashtray. If found a few down there as well. ....as well as your power seat fuse. You might have to remove the ashtray and/or the ski slope panel.
(FWIW, I lengthened the wires and put the fuses under the cubby box on my '87 Ser III for easier access)
Old May 17, 2015 | 05:52 PM
wildman's Avatar
Well I found one fuse behind the drivers panel.
Then I found 2 more under the drivers ash tray.
One of those 2 is a 2 amp and it took forever to get the holder apart.
The fuse is not good, however, I might have shaken it during removal.
There is absolutely not enough slack in the wire to put it back together without some type of special tool. I tried needle nose pliers and still did not get it.
I know when to give up and try later. I need someone with small, strong hands to reach thru the the ash try opening
They darn sure did not put that holder in a good area.
Old May 17, 2015 | 05:57 PM
wildman's Avatar
I found 2 fuses under the drivers ash tray.
Old May 17, 2015 | 06:05 PM
Jose's Avatar
you might check that one of those is not the fuse for the driver's seat adjustment motor.
check the seat movement to see if it works.
Old May 17, 2015 | 06:27 PM
wildman's Avatar
Seat still works; so hope thr one I can't get back together is the radio
Old May 17, 2015 | 06:31 PM
wildman's Avatar
By the way, when I turn the radio on, the antenna goes up.
Old May 17, 2015 | 07:11 PM
Jose's Avatar
ok, then your radio has 12v power.
What color is the wire in the fuse holder that you can't undo? If the wire is white/pink, that is the seat motor fuse.
Old May 18, 2015 | 06:21 AM
wildman's Avatar
The wire is solid red.
I got it apart, just going to have trouble getting it back together
Old May 18, 2015 | 06:47 AM
Jose's Avatar
the wire might be pinched somewhere, trying to work from the ashtray opening is impossible, normally you remove the console complete panel with the ash trays attached.
first remove the center console lid complete with the chromed hinge (the hinge in the back of the lid), then remove the lid catch by prying it carefully, then remove the black plastic tray.
then you remove the shifter knob by unscrewing both halves in opposite directions of each other,
then you disconnect all the switches from the rear of the ski slope labeling them one by one, then you remove the one screw at the front top of the ski slope, then you can carefully lift the console panel.
Old May 18, 2015 | 07:44 AM
wildman's Avatar
I did try removing the console lid
I got that off without a problem
Then I tried to remove the console tray. It feels like something is holding it
I have removed all screws including the one in the face.
The back part is loose but there is a lot of resistance at the front of the tray
Any ideas ?
Old May 18, 2015 | 07:50 AM
Doug's Avatar
The front of the tray is held firm by the latch.
Foggy memory here but as I recall the only way to remove the latch is to gently pry it out.....and hope you don't break it. Jose might have a better idea.
Old May 18, 2015 | 08:18 AM
Jose's Avatar
yes, you need to pry off the lid catch before the tray can be removed, a pita to remove.
I have used two very thin flat screwdrivers, pushing one under one side of the catch, then pushing another under the other side, 2 switchblades or kitchen knives work nicely. It is held in place by a "spring" tensioner, same principle as the fuel tank switch and the other three panel switches.
if you break it, go to any Maytag appliance store and get a Clothes Dryer catch, it is the same part except white, but maybe they have them in black.
Attached Thumbnails Radio Line Fuse Location-xj-console-catch-01.jpg   Radio Line Fuse Location-xj-console-catch-02.jpg   Radio Line Fuse Location-xj-console-catch-03.jpg
Old May 18, 2015 | 09:26 AM
wildman's Avatar
Thanks guys
Will give at a try
Old May 18, 2015 | 05:28 PM
wildman's Avatar
well I replaced every fuse I could find; still no radio
Old May 18, 2015 | 05:43 PM
Jose's Avatar
I just do not think the radio fuse would be located under the ashtray in a 1985 which was most likely built in 1984.
is your car a Vanden Plas? if yes, the red wire is for the rear seat's cigar lighter, not for the radio.
you said that when you turn the radio ON the antenna goes UP, then you do have power to the radio. The secondary radio wire is for radio memory.
can you post a picture of your radio?
Old May 18, 2015 | 06:35 PM
Tar's Avatar
Tar
In my '87, the fuse for the radio is in fact under the console just ahead and left of the shifter. It was a two-amp fuse on a red wire. I read somewhere that newer radios do better with a 10-amp, so when I installed my Blaupunkt, that is what I replaced it with.
Most modern radios have a 10-amp blade fuse in the back of the radio unit itself. I'm sure you've checked it already, but thought I'd mention it
Andrew.
Old May 18, 2015 | 07:04 PM
wildman's Avatar
It is just an XJ6.
I am going to try to post a picture.
I have a feeling there is a fuse behind the drivers panel I am not finding.
1985 Radio
Old May 19, 2015 | 06:46 AM
Jose's Avatar
yes, that is a 1985 factory radio, same radio I have in my 1984, connects the same way as the 1983-1984 radios, (Andrew, there is no blade fuse in the back of this radio). The fuses are contained in two separate fuse holders, one for 12 volt power with ignition, one for constant 12 volt power for radio presets memory. Two plugs connect the radio, one plug for speakers, one for 12 v power and antenna. Then there is a Ground Strap connected by a phillips bolt to the rear of the radio, and last is the antenna plug inserted to the back of the radio.
wonderful car by the way.
at this point I would remove the console panel, a/c controls knobs and panel, and remove the radio for a closer inspection, then you can study and inspect the harness and folow the wires to and from.
try to not break the radio's outer edge plastic frame, it breaks easily. It is the first thing you need to remove before the a/c controls and panel.
