re-attaching trim piece
Old May 17, 2016 | 03:13 PM
vetter65809's Avatar
Default re-attaching trim piece
I have a chrome trim piece, approximately 12" long, that is located on the trunk lid under the lock. Are plastic inserts required to re-attach this piece? If so, does anyone know where they can be obtained? thanks
Old May 17, 2016 | 07:07 PM
Jose's Avatar
What car and year? In the Series 3 XJ the chromed bar from side to side, the license plate frame, and the emblems have pins onto which a plastic bushing or ferrule slides over, then from behind, a locking barrel is slid over the bushing, a pita to install. Go to an ACE Hardware and find automotive nuts that cut their own thread as you turn them clockwise. Ford and GM use those nuts to attach emblems to grilles. Bring the part with you so you get the correct size nut for the pin. The picture below shows the nut on the right, ignore the fastener on the left of the picture.
Old May 17, 2016 | 08:17 PM
Jose,
thanks for the feedback, the car is a 1974 XJ12. Because of the inside panel on the trunk lid and lack of cut outs in this panel, I cannot see or get close to all of the tabs on the chrome piece. I may be able to put a nut on the center tab but that would be the only one. It looks like the other chrome pieces on the rear of the trunk lid only have plastic inserts in the trim tab holes to hold pieces in place. Would like to try and locate some of these?
Old May 18, 2016 | 05:40 PM
Jose's Avatar
If anyone can get new ones it might be SNG Barrat USA Store. Check their online catalog.
http://www.sngbarratt.com/Home.aspx?b=US
Old May 19, 2016 | 08:12 AM
Jose,
thanks for the info. I was unaware of SNG Barrat USA, I phoned in, it is a plastic insert, I have ordered what I need, thanks
Old May 19, 2016 | 11:24 AM
Jose's Avatar
you welcome vetter, they are a UK company with a US store. I think they give us 10 percent off if you mention you are a member of this forum, but maybe not on a small order like that.
anton5678
Jul 10, 2016 08:50 AM
TheCounty
Jun 11, 2016 09:01 AM
Narda 1
May 16, 2016 06:34 AM
jeffn
May 15, 2016 09:19 AM
TerryinNC
May 12, 2016 12:20 AM
