right side only brake failure
Old Jun 15, 2017 | 12:07 AM
wmcraw's Avatar
Default right side only brake failure
1990 xj6 sovereign
brakes on right side (passenger) only will not work front and rear
left side (driver) front and rear work normally
installed new pads and rotors and cleaned sensors o all wheels
right side front and rear bleed normally
left side no fluid came from bleed valve
any suggestions would help
Old Jun 15, 2017 | 06:09 AM
Firstly, welcome to the Forum.
Please do an Intro in the New Members Area when time permits.
Your 1990 XJ6 is known as an XJ40 in Jaguar land.
A quickie repost in that section will get the answers you need.
Old Jun 20, 2017 | 12:55 AM
wmcraw's Avatar
I have discovered the answer to my problem brakes on right side (passenger) only will not work front and rear left side (driver) front and rear work normally
the answer is that the flexible brake line from the caliper to the steel line is clogged with gook that can not be penetrated by a wire
new line is required
