Series 1 lic. plate bulbs
Old Jun 6, 2016 | 11:30 PM
smith356's Avatar
Default Series 1 lic. plate bulbs
I need the bulb # for license plate. It's for the older style that have it built into the bumper. I know the size of the base, and manual says 6 watts - after that I'm lost !
Thanks, Jim
Old Jun 7, 2016 | 12:37 AM
o1xjr's Avatar
There are two bulbs in there, mine are 12V/3W. The base is 9mm diameter and the bulb is 12mm diameter. You should be able to find them at any auto parts shop.
Series 1 lic. plate bulbs-dsc_6492.jpgSeries 1 lic. plate bulbs-dsc_6493.jpgSeries 1 lic. plate bulbs-dsc_6494.jpg
Old Jun 7, 2016 | 02:41 AM
smith356's Avatar
Yes ! That's the one - Once again, thank you, thank you !!
Old Jun 10, 2016 | 03:49 PM
anjum's Avatar
Get LED equivalents. They don't bake the lens.
Old Jun 10, 2016 | 10:23 PM
If you do get LED replacements for those bulbs be sure you get units with side emitters rather than only straight on. Otherwise your OEM 6w incandescent will be functionally brighter.
Old Jun 11, 2016 | 08:49 AM
JagCad's Avatar
Good advice from the mistress of LED's!!
Did another of her suggestions. Exercised the panel light rheostat.
Yup, seemed brighter in the garage with shop lights off. Don't think my Optilite is working. Hmm, back n the console. Well, mebbe, but not for a while. Other tasks at hand.
Fooled with trick many headed screw driver. Two AAA's once powered teeny work lights. Bum, one of it's LED's pig tails busted off. Back to work sans extra light. Fixed big floor fan, though!!
One of my exterior extensions keeps burning off the female end!!
6 bucks plus at ACE. Male ends less??? Gals are expensive but, as the female clerk opined, "we are worth it"!!!
Carl
