SI XJ6 Fuel Pump
Now that school is out I've finally got time to delve into my project '72 XJ6. First up is the fuel system. Today I removed the fuel pumps and completely stripped and cleaned one. Upon testing it on a battery I could hear the centre go up and then upon removing the cables it weoukd go back down, so movement yes but no continuous whirring/ticking as I expected but granted it was not properly mounted and wired and was just sucking air so hopefully it's operational. I went to hook it back up and figured I'd go ahead and test if the wires were hot, and nothing. I tested both wires with a test light, and nothing. I cleaned all the connections to the ground and the clips on the positives and still nothing. I consult my literature and find the fuse box but there's no fuse for the fuel system so I guess what I'm getting around to asking is if there is some sort of relay or other fuse not behind the instrument cluster or if anyone has dealt with rewiring (which I'd strongly prefer not to have to do). Any help is much appreciated, thank you!
