Side Window Adjustment?
Old Jun 9, 2017 | 06:53 AM
Dale Konkol's Avatar
Default Side Window Adjustment?
My drivers side window when closed is leaving a small 1/8-1/4" gap at the top rear corner of the glass.
I can pull up and down on the glass and it does seem to have a small amount of play. It almost seems like the glass is ever so slightly cockeyed so that the top rear doesn't seal properly. The window goes up and down normally and smoothly. Took door card off and the metal panel that cover the regulator. I couldn't see anything obvious so I reassembled after lubricating and I still have the same issue.
Has anybody had this problem before?
Any suggestions?
Thanks.
