Which starter terminal is correct?
Old Aug 2, 2022 | 01:32 PM
Yellow series3's Avatar
Default Which starter terminal is correct?
The Lucas starter in my 1987 XJ6 4.2 was acting wonky so I followed Doug's excellent diagnostic check list. When I jumped the starter relay white/red wire to the battery I got nothing. So I pulled the starter and darn but the lower end of that wire had fallen off the solenoid spade terminal on the starter. No wonder it wasn’t working. So my question is that on the starter there are two spade terminals: which one does the relay wire go back on? The one on the left is longer than the one on the right. Neither have any markings on the black plastic at the base. Your help will be greatly appreciated.
Jeff
Old Aug 2, 2022 | 05:55 PM
Doug's Avatar
I'd go with the shorter terminal. It looks more robustly fixed, as one would expect for the solenoid operation. The other one looks like an auxiliary terminal for cars that need a "12v when cranking" supply
retroren
Oct 19, 2021 01:56 PM
cityboy
Apr 27, 2021 11:11 AM
wrischan
E type ( XK-E )
Apr 6, 2021 07:30 PM
Starcaster
Jan 27, 2021 06:02 AM
Uno Strzelichowski
Mar 22, 2019 12:22 PM
