[Jag-lovers Forums] [XJ-S] Xls 1996 convertible 1/4window stuck and not going down wi
Old Feb 5, 2023 | 05:39 AM
Yurydash's Avatar
Default [Jag-lovers Forums] [XJ-S] Xls 1996 convertible 1/4window stuck and not going down wi
XJS 1996 convertible 1/4window on driver side stuck and not going down with a roof and not fully closing . Driver seat cannot recline . How to fix please dashev007@gmail.com
Old Feb 5, 2023 | 08:08 PM
Vee's Avatar
Vee
I need a bit more information.
Did both issues happen at the same time, or are you not sure?
Is the quarter window stuck now, or is it working sporadically?
Is the roof not closing all the way?
I’m afraid I’m not understanding your post fully.
There is a fuse for the seat recliner. (Under drivers side dash, 20A fuse, Position 12.)
The motor for the quarter window may be jamming. You'll be able to tap that motor with a long stick or something and it will work again, but for how long is anyone's guess. I have a post that solved my problem, at least for a few years anyways. Search my posts and you should be able to find it, with photos!!
Old Feb 5, 2023 | 09:55 PM
stran0020's Avatar
There’s a thermal fuse and relays in the back trunk above battery that you should check also.
jag1996
Sep 13, 2016 04:00 PM
karata
Feb 11, 2015 10:51 AM
