1989 Jaguar XJS
Old Aug 17, 2012 | 01:19 PM
Travelboy5's Avatar
Default 1989 Jaguar XJS
I have an XJS V12 showroom with 29K miles. My buddy drove the car and agree's it is a puff but wondered why it would kick into overdrive or passing gear. Is there a passing gear or overdrive? thanks.
Old Aug 17, 2012 | 05:42 PM
(moved from General Tech to XJS section)
Welcome to the forum Travelboy5,
Please visit New Member Area - Intro a MUST section and post some details about yourself and your vehicle.
That way all members will see your Intro and you'll get a welcome with advice on where to post your questions.
Old Aug 17, 2012 | 06:30 PM
Flint Ironstag's Avatar
Default First of all...
... welcome.
Second of all:
Unless modified (sounds highly unlikely), the car has a 3 speed automatic transmission.
Basically, if you're cruising in 3rd between roughly (someone else feel free to chime in with the exact range) 40mph and 80mph, and depress the accelerator all the way to the floor, the kickdown switch engages and the transmission shifts to 2nd gear. I'm pretty sure it will not kickdown from 2nd to 1st under any circumstances.
Most likely this is what you are experiencing. It should still be smooth though. If this is happening without flooring it, something is wrong.
Post some pics!!
Old Aug 19, 2012 | 07:08 PM
Doug's Avatar
Not sure if I understand the question,but....
Your XJS has the Jaguar version of the GM Th400 tranmission. It's a 3-speed auto; no overdrive.
An electric switch on the throttle cable will allow a full throttle "kickdown"/downshift into a lower gear/passing gear.
The TH400 also has a "part throttle downshift", vacuum controlled, which will allow a 3-2 shift at partial throttle, depending on engine load and road speed.
Hope this helps a little
Old Aug 20, 2012 | 09:12 AM
Travelboy5's Avatar
Thanks everyone... Seems like it is quite normal then because the ride is smooth and fast...
Old Aug 20, 2012 | 01:23 PM
wrightbenz's Avatar
you have to push the pedal all the way to the floor for a downshift. If it will not downshift it is the micro switch next to the round throttle linkage. It fits into a little notch in the throttle cable sheath actually and there is a piece on the cable that when floor closes the switch.
Check the switch by actuating it with your finger it should click, if it doesn't click press it harder and it may snap loose and begin working again.
Ask me how I know all of this LOL
1100me
Aug 27, 2020 11:37 PM
DrScientist
Dec 9, 2015 07:36 PM
kenatofc
Oct 27, 2015 06:48 AM
David Mason
Sep 3, 2015 03:17 AM
