1992 XJS V12 Convertible ATF top up.
I need to top up my transmission but cant find Dexron 11 or 111. What's the ATF that I can use in my car? I know it's a GM 400 and many sites recommend Amsoil ATF for that transmission but I thought I'd double check with our experts on this board.
Thanks in advance.
Stephen
Thanks in advance.
Stephen
Ordinary Dexron will work just fine. I'm surprised you can't find Dexron III, it has to be the most common fluid out there. Often generically called ATF, make sure the bottle says it meets Dexron II or III and it will work. All the major brands make a compatible fluid.
1100me
Sep 23, 2014 05:19 PM
orangeblossom
Jun 22, 2014 05:59 PM
