1993 XJS Coupe - Exterior driver door handle assembly problem
Old May 24, 2017 | 06:13 AM
514Jag's Avatar
Default 1993 XJS Coupe - Exterior driver door handle assembly problem
Hello guys,
I am replacing the driver side exterior door handle, since the original one broke recently (the litlle lever snapped off at the base - common problem). The issue that I have is that I am unsure how to re-assemble the torsion spring and white plastic spacer shown on the photo - I know, I should have been more careful during disassembly Any help would be very appreciated.
Attached Thumbnails 1993 XJS Coupe - Exterior driver door handle assembly problem-img_20170523_211448.jpg   1993 XJS Coupe - Exterior driver door handle assembly problem-img_20170523_211723.jpg
