1995 xjs Erratic Warning Lights No Codes
Old Nov 16, 2016 | 10:37 PM
twncty's Avatar
Default 1995 xjs Erratic Warning Lights No Codes
Yesterday my 1995 Jaguar XJS 2+2 started to flash the following warning lights simultaneously: Brake, Hand Brake, Seatbelt and Washer fluid. They all come on for a second and go off. It might be 2 seconds or a couple minutes before it does it again. The climate control ac turned itself on too. I really don't know where to start on this one. There has been no difference in how it drives. Everything else operates fine. Thanks for your help.
Old Nov 16, 2016 | 11:32 PM
Doug's Avatar
Might be a failing coil
https://www.jaguarforums.com/forum/x...kering-172333/
Old Nov 17, 2016 | 09:37 PM
twncty's Avatar
Thanks so much!!
Old Nov 18, 2016 | 08:20 AM
Spikepaga's Avatar
That happened to me and it was not a coil. It was the DAC11139 multifunction unit. I took it out, cleaned the connector and it has not happened again in 2 years. I remember I even had warning chimes going of sporadically while driving.
