1996 xjs Temp sender transducer
Old Feb 3, 2022 | 01:15 PM
Softball60's Avatar
Default 1996 xjs Temp sender transducer
As I continue on with updating any issues or potential issue I am now replacing the temp sender transducer (unit that sends signal to the gauge)……..I think.
The temp gauge did not seem to be displaying the proper temp. I looked at the wire connection from the sender to the gauge. Wire and connection was very dirty and I noticed that the center portion of the sender (where the blade sticks up) seemed to move. I was thinking this was the issue.(gauge not receiving the proper signal) and displaying erratic temp. The car runs perfect and does not overheat!!
I replaced the sender transducer today thinking this will take care of the issue. After replacing the transducer and a new blade female terminal, upon turning the ignition on the gauge pegs to the RED OVERHEAT SIDE. I took the car for a spin….the gauge did not move and the cooling system was cold.
WHAT DID I DO WRONG OR IS IT SOMETHING ELSE BESIDES THE NEW TRANSDUCER?
Thanks as always for your input
Softball60/Paul
Old Feb 3, 2022 | 05:12 PM
jal1234's Avatar
Just because your transducer is new, does not mean it's good. Put your old one back in and see what happens.
Old Feb 3, 2022 | 05:19 PM
jal1234's Avatar
Oh, and as temperature goes up, resistance in the sender goes down. As a result, a shorted sender would peg the gauge to hot.
Old Feb 4, 2022 | 08:39 AM
RickE's Avatar
Are you sure you have the correct transducer? My understanding is that they are no longer available. Could be confused as it's been a while.
Old Feb 4, 2022 | 09:08 AM
jal1234's Avatar
I tried getting an original recently, but it was NLA. Aftermarket ones are available.
Old Feb 4, 2022 | 11:32 AM
Softball60's Avatar
I cleaned up the old unit and reinstalled. It seems to be functioning and the gauge indicates ……..NO MORE RED LINE TEMP! Upon startup.
Softball60/Paul
Pwilson45
Oct 21, 2016 11:22 AM
Harry Dredge
Jun 28, 2016 03:38 AM
Colonelxke
E type ( XK-E )
Jun 18, 2016 01:09 AM
sidescrollin
Oct 13, 2012 02:45 AM
