New to this forum.
I just purchased a 1990 Jaguar XJS. The engine harness has been damaged in several spots by pack rats. Any ideas where to get a new harness? I haven't been able to find anything.
There is a fairly current thread about building a harness of your own if you are handy. Just search injector harness. Or, try SNGBarratt or XKs unlimited. I was checking this myself recently and they are not cheap.
Depends on WHICH harness you need. There are...a few.
if you want new/oem there is a guy who makes them, I've had luck with his products both injector and gauge sensor harnesses all redone with new original plugs. Contact Andrew at JaguarSpecialties, he comes on the forum occasionally to.
If you also look under XJ12 you will find more there, they are not particularity well cross referenced, for example this is also the correct inj harness for my 82 XJS but not directled listed as so ........The harness on the other hand is superb.
