87 xjs engine harness for 90 xjs
Old Mar 28, 2020 | 11:49 AM
Ashfro's Avatar
Default 87 xjs engine harness for 90 xjs
Will an 87 xjs 5.3 engine harness match with my 90 xjs 5.3. Just bought a 90 xjs barn find and all harnesses under the hood are damaged.
This cleaned up really well and I would love to see it running soon
Attached Thumbnails 87 xjs engine harness for 90 xjs-123_1-1-.jpeg   87 xjs engine harness for 90 xjs-20200325_153601.jpg   87 xjs engine harness for 90 xjs-00i0i_uqhi0veayj_1200x900.jpg   87 xjs engine harness for 90 xjs-20200321_134729.jpg   87 xjs engine harness for 90 xjs-20200321_135118.jpg
Old Mar 28, 2020 | 12:24 PM
jag-reflex's Avatar
90 is Marelli? If so, i doubt it but someone will be more definite than me..
Old Mar 28, 2020 | 03:16 PM
VancouverXJ6's Avatar
Most of it will probably be different. Sensor cluster might be same but 87/90 had different ignition and I believe 87' had the 6cu ecu maybe different wiring there to...Im not pulling my cars ecu to compare and confirm.
if you need wiring theres suppliers in UK/US
Old Mar 28, 2020 | 03:55 PM
jag-reflex's Avatar
87 has 16cu but Lucas
melhookv12
Jan 12, 2021 05:22 AM
