94 XJS 4.0 stalls at stop
Old Apr 1, 2021 | 03:51 PM
Jaglady96's Avatar
Default 94 XJS 4.0 stalls at stop
we have cleaned throttle body, replaced mouse junk filled air filter, replaced heat sensor, adjusted idle
car was great for one day then doing same thing- idles & runs fine except when at a stop
what now ? Idle valve replacement? MAF sensor?
Old Apr 1, 2021 | 07:01 PM
jerry_hoback's Avatar
Check for vacuum leaks. There are lots of vac hoses especially around the evap canister. Good luck, doesnt sound like an expensive fix.
Old Apr 3, 2021 | 09:20 AM
Vee's Avatar
Vee
Would like more diagnostics. Does it stall out at every stop? Warm engine? Cold engine? What if you keep your foot on the gas pedal, keeping the RPMs up when stopped? What is your RPMs at idle? Cold? Warm? Is it smooth? Lumpy?
If you had mice in your air filter, they may have destroyed your MAF. Have you cleaned that?
Old Apr 4, 2021 | 08:07 AM
orangeblossom's Avatar
Could easily be the Throttle Body Spring
As Jaguar upgraded the Spring for a stronger one, which may have something to do with the way that She idles
Old Apr 4, 2021 | 08:17 AM
RickE's Avatar
My stalling problem with my 1996 was fixed when I replaced the EGR valve. I don't know if cleaning the existing valve would help, but it might be worth a try.
NOFIS
Dec 6, 2020 06:03 PM
vpickering
Nov 23, 2019 09:30 PM
jazzwineman
Oct 5, 2015 07:08 AM
93greenconv
Jun 20, 2013 09:31 AM
93greenconv
Feb 8, 2011 03:05 PM
