94 XJS...manual over ride to pull up conv't. top
Old Jan 9, 2023 | 03:47 PM
van1243's Avatar
Default 94 XJS...manual over ride to pull up conv't. top
94 XJS convert. top will not go up. Is there a manual over ride to pull it up?
Old Jan 9, 2023 | 03:58 PM
Vee's Avatar
Vee
check response on your other post.
Old Jan 11, 2023 | 10:38 AM
MHF25's Avatar
The hand (parking) has to be engaged in order to operate the lowering or raising of the rag top.
Old Jan 16, 2023 | 09:16 AM
Patrick 1989 XJS's Avatar
I have a 1989 convertible and there is a manual override. The operation is shown in the original handbook. I have to gain access to the hydraulic control valve located in the storage compartment behind the seats. Open the cover panel to the hydraulic valve with a coin. Turn the hydraulic valve clockwise to the position marked MANUAL and push the top down. Hopefully this is the same for your car.
Old Jan 16, 2023 | 09:50 PM
malc4d's Avatar
In the '94 it sits above the pump in the trunk.
Have you tried first checing its in park /neutral and the hand / emergency brake is on ?
dibbyandco
E type ( XK-E )
Nov 19, 2022 10:47 AM
ChrisMills
Sep 14, 2022 06:51 AM
95 Cat
Dec 27, 2020 12:56 PM
stonehenge kid
Jul 24, 2011 05:45 PM
