ABS accumulator sphere on '88 coupe - failing?
Old 10-01-2022, 10:01 AM
Mozambique's Avatar
Originally Posted by orangeblossom
Hi Mozambique
The Generic Accumulator Ball was about £150 though might be a bit more now
If your buying this Car from a Garage, I would want everything working, including the ABS or if not I would walk away, as if you can't or do not want to work on her yourself, She could cost you a fortune in the long run and if you ever wanted to sell her, then any potential purchaser would also want everything working, especially the Brakes!
There's always another XJS and it always sometimes never pays to buy the first one you see
Actually, brake warning light aside, the car is very well sorted and comes with extensive documentation on work done by a well respected Jag club owner. Its not the first one I have looked at, but it does tick all the boxes for me. As I said, the brakes work fine as-is without ABS enabled. If that is road-legal here and it seems it is, then I am not so concerned. I do however appreciate you raising some valid points.
Old 10-11-2022, 04:44 PM
Mozambique's Avatar
Quick update gents:
Accumulator sphere replaced and red warning light gone...............will determine if blink test done.........
Dale Larson
04-21-2021 05:42 AM
bullittandy
03-03-2017 04:44 PM
Saspc
05-26-2016 05:58 PM
orangeblossom
07-13-2015 04:24 AM
orangeblossom
05-18-2015 07:43 AM
Quick Reply: ABS accumulator sphere on '88 coupe - failing?
