aircon pump cyclin on/off
Old Feb 7, 2016 | 02:20 AM
Hoppy's Avatar
Default aircon pump cycling on/off
Hi all, my Air con pump cycles on/off continuously, noticed this while warming the car up to attempt bleeding the cooling system, so heater was on hot.
it cycles at about 5s on/off. any ideas?
the air does get cold normally although I get hot air out of the top and dash vents when driving - cold at feet - I reckon that's another issue
Old Feb 7, 2016 | 02:35 AM
Hoppy's Avatar
1990 built marelli V12
Old Feb 7, 2016 | 03:45 PM
Doug's Avatar
Some cycling is normal either in response to system pressures or to the icing switch that cuts the circuit if the evaporator start to ice up.
Every 5 seconds doesn't sound quite right, though. Might be slightly low on Freon. I'd have the hi-lo pressures checked.
Old Feb 7, 2016 | 03:51 PM
Jagboi64's Avatar
Short cycling is a sign of being undercharged. As Doug mentioned, have the pressures / weight of refrigerant in the system checked.
