Battery cable
Old Aug 20, 2017 | 03:22 PM
BC XJS's Avatar
Default Battery cable
I have a 86 XJS. I need to replace the battery cables. Can anyone tell me what route it takes?
Old Aug 20, 2017 | 05:17 PM
warrjon's Avatar
Underneath the car in the transmission tunnel.
May I inquire as to why you are replacing the battery cable?
Old Aug 22, 2017 | 03:31 PM
BC XJS's Avatar
General maintenance. I'm changing battery, battery switch, hi torque starter and thought I'd do the cables at the same time. The old one is hart as rock and the insulation will probably fail soon.
Old Aug 22, 2017 | 05:09 PM
warrjon's Avatar
Current draw from the starter motor could be as high as 300 - 400 amps, if you use too small a cable you will have either starting issues or the cable will get hot and melt the insulation.
I would recommend at least 600 amp cable.
Old Aug 23, 2017 | 05:51 AM
baxtor's Avatar
That will be no small task if you mean the long trans tunnel cable. Almost a transmission out job so l would make sure it actually needs replacing.
It is a pretty stiff cable so don't confuse that with ageing insulation.
