borg warner conversion for xjs
Old Oct 31, 2009 | 08:30 PM
mbalce's Avatar
No idea personally but if you post this question in the XJS forum you are going to get a lot more people that may know seeing it...
Old Nov 1, 2009 | 03:27 AM
Cadillac's Avatar
Moved off to the XJS Forum
Old Nov 1, 2009 | 07:02 AM
Doug's Avatar
Originally Posted by jagcollector
Does anybody know what I have to do to convert my 89 to the later model 90 and up trans. Iv'e had seven xjs and in every case the GM 400 failed, and the 90, 91 ,and 92 up kept on going.
The GM 400 trans was used from mid-1977 right up until the introduction of the 6.0 V12, which was 1994 model year as I recall. It was then replaced by the GM 4L80E which is essentially a 400 with a 4th gear added. As bolt patterns were different you'll need an adapter kit from Johns Cars or a similar vendor....which in turn requires the use of a trans from a GM model, not Jaguar.
A better bet is changing to the GM 700 trans, later designated 4L60 but you'll still need a conversion kit
Old Nov 1, 2009 | 04:30 PM
Doug's Avatar
Thanks for the heads up...never even heard of the 4l80e but it sounds like the way to go
Actually, no, it would be difficult. The 4L80E is electronically controlled (thus the "E") so, besides adapting the transmission itself, you'd have to add in the entire electronic control system.
The 4L60 is a better, easier choice
scooternva
29
Mar 25, 2025 12:45 PM
Vector
US Lower Atlantic
Sep 13, 2015 03:01 PM
Nasayr
Sep 9, 2015 06:20 AM
sklimii
Sep 5, 2015 06:04 AM
