A/C Sight Glass
Old Jun 4, 2013 | 06:44 AM
Vee's Avatar
Vee
Default A/C Sight Glass
I just realized that the new drier I installed comes with a sight glass... the OEM drier does not.
I did not align the sight glass to be pointing up. Instead, its pointing at about 135 degrees (assuming 0 degrees is straight up). I can see it through the grille though.
This brings up two questions:
a. Since it's not pointing up, is it doing any good?
b. Since the OEM system does not have a sight glass, it is even useful?
Thanks.
Old Jun 4, 2013 | 08:20 AM
sidescrollin's Avatar
imo it is still useful but it isn't necessary. If you ignore it, run your gauges and still pull a proper vacuum and then fill according to your gauges that sight glass isn't going to tell you anything more than your gauges ever could.
Old Jun 4, 2013 | 08:25 AM
Vee's Avatar
Vee
Thanks. I did do that.
I watched the gauges as well as weighed the refrigerant as it went in.
I believe I am within the weight tolerance, and on a 90 degree day, I got the high pressure side to 180F. The service manual really didn't tell me anything about what to read on the low side, so I basically ignored it. It seems to sit steadily at about 50F.
blackenedindustries
Sep 30, 2015 10:17 AM
dan102877
Sep 29, 2015 06:47 PM
HuncaMunca
Sep 27, 2015 02:47 PM
vacolorito
Sep 25, 2015 09:29 AM
