Clutch slave cylinder
Old Nov 4, 2019 | 03:30 PM
Carmichaels's Avatar
Default Clutch slave cylinder
Hi, I need a new clutch slave cylinder for my 94 XJS 4.0. Im told that my VIN# 189— is out of the range of the only available cylinder, prior to VIN# 188— and it will not work on my vehicle.
Hard to imagine what the change might be that renders it .not usable on my car. Can anyone shed light on this? Thanks for your input
Old Nov 4, 2019 | 05:21 PM
As you haven't posted an Intro in the four years since you registered, welcome to the forums Carmichaels,
I've moved your question from General Tech Help to XJS forum. This is the place to post technical questions about your model.
Old Nov 4, 2019 | 11:01 PM
Thank You, I appreciate it!
Old Nov 4, 2019 | 11:54 PM
Doug's Avatar
Can't shed any light on the matter.
If all all fails it shouldn't be a problem to overhaul your existing cylinder.
I've used this company with good results; I reckon there are others equally good
Apple Hydraulics
Old Nov 5, 2019 | 04:34 AM
ptjs1's Avatar
Carmichaels,
The early cars used a clutch damper but I'm not sure if your late car has one? There's a difference in the part number of the pipe that goes from the m/c to the early clutch damper which might question if you have a damper or if the thread fitting on the master cylinder is different on the late cars. Why don't you rings someone like SNG Barratt and ask them if the early cylinder can fit a late car?
Good luck
Paul
leep123
Jul 13, 2019 05:21 AM
JohnV
Jul 26, 2018 12:53 PM
Vintagecarlover
Jul 19, 2016 01:42 PM
Greg Reed
Sep 11, 2015 08:41 PM
