Coolant resevoir
Old Dec 12, 2012 | 09:13 PM
macdoesit's Avatar
Banned
Default Coolant resevoir
I have looked all over no coolant resevoir . Is there one?
Old Dec 12, 2012 | 09:30 PM
JTsmks's Avatar
I think what your looking for is an overflow tank...it is in your drivers side fender, behind your tire tread is a panel on the fenderwell that opens to access it. Beware that the only rust on my 86 is in this area, the designers mounted the tank on top of the rocker basically and on the sides put foam. The drain gutter is right over top of this so the foam gets soaked with water and holds it between the outter fender skin and the tank brace.
Old Dec 13, 2012 | 06:16 PM
macdoesit's Avatar
Banned
Thank you,JTsmks.
MrWhite
19
Jun 14, 2022 07:49 PM
X308XJR
May 20, 2019 06:50 PM
04Xjrsteve
May 7, 2019 04:06 PM
vwbusbits
Oct 13, 2015 03:43 AM
