Ecu photo needed
Old 01-07-2019, 01:16 PM
brinny's Avatar
Default Ecu photo needed
Could anyone post a photo showing the ecu fitted in the passenger footwell. My car came with it laying in the footwell floor and there are no obvious fixing points. I know it has three holes in the ecu to fix it to the car but want to make sure it goes back correctly as there is a panel to cover it and I need to make sure that will go back on . Thank you for any help in advance.
Old 01-07-2019, 02:33 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
The ECU mounts to the back of the panel. There should be rubber grommets to mount the panel to the car. I'll take some pics for you.
Old 01-07-2019, 02:56 PM
brinny's Avatar
Now that makes sense. I did see some rubber fittings. That will be a big help warren thanks, if you haven’t taken stuff off it’s always harder to work it out. Cheers.
Old 01-12-2019, 03:48 PM
warrjon's Avatar
Sorry Bob I have not had a chance to get out and take a photo of the ECU, my car is up in the air ATM and I need to remove trim to get the ECU out.
Old 01-13-2019, 03:22 AM
brinny's Avatar
Cheers warren. No rush
sales@ECU Tuning Group
05-06-2020 11:26 AM
orangeblossom
04-29-2017 09:20 PM
brinny
12-31-2016 06:41 AM
DrScientist
09-01-2015 09:19 AM
mphy98
02-28-2011 07:47 PM
Quick Reply: Ecu photo needed
