EGR valve
Old May 16, 2022 | 07:36 AM
vmaxie's Avatar
Default EGR valve
Anyone have any tips regarding replacing EGR valve on a 1996 Jag XJS 4.0L
One of the bolts appears to be directly under the fuel rail.
Any assistance would be much appreciated.
Thxs
Old May 16, 2022 | 11:03 AM
Vee's Avatar
Vee
I don't recall having to remove the rail to replace the EGR, which I have done.
Is it simply the plastic cover that's blocking it?
Old May 16, 2022 | 11:12 AM
Softball60's Avatar
Vmaxie,
where are you located…..I’m in Venice……I would be willing to help if you are close by.
THE PROCESS IS SIMPLE
1. Remove fuel rail cover……starbit fitting…..by a cheap set at Harbor Freight. Unplug connector
2. The actual bolts holding the EGR down is 10mm size socket?…Again cheap set at Harbor Freight
3. I used a 1/4” drive with extension and 10mm socket
GOOD LUCK
Softball60/Paul
Old May 21, 2022 | 02:52 AM
vmaxie's Avatar
Thxs Softball60
Put the new EGR in yesterday
Was pretty simple as U said
x type why u mean
Jan 19, 2019 04:04 PM
1stone98xjr
Mar 28, 2014 11:13 PM
Ants2505
Dec 8, 2013 04:27 AM
terryt58
Nov 9, 2013 04:48 PM
aldol
Jan 3, 2013 10:49 PM
