emissions discard
Old Jul 16, 2015 | 09:33 PM
mtpckts's Avatar
From: collinsville,Ill-18 miles from downtown ST,louis
Default emissions discard
i want to get rid of the air pump and etc on 1989 XJS 5.3 . what do in need to due. what stays and what go"s. :icon_question
Old Jul 16, 2015 | 09:48 PM
Broken_Spanners's Avatar
Honestly the car runs just as well / better with those bits if stock IME / I personally wouldn't remove the same.
Is your pump making noise or have other issues?
Old Jul 16, 2015 | 10:10 PM
mtpckts's Avatar
yes it stock just want to clean up engine bay.
Old Jul 18, 2015 | 08:17 PM
JameyXJ6's Avatar
I removed my airpump and mechanical fan (and A/C because mine is a convertible) and relocated the alternator with a GM style where the airpump used to be.
Old Jul 19, 2015 | 07:14 PM
Katoh's Avatar
I removed all the plumbing for the air pump on mine to gain better access and clean it up a little, stage two is like JameyXR6 is to remove the pump and move the alternator to that position and put in twin thermo fans. Only I will use a smaller after market AC pump and put it where the alternator was.
For the air lines, simply remove them and disconnect from the back of the motor, you will then have to plug all those holes where they went into the manifold, I simply tapped them and used a bolt and washer. While you are digging around down there its a good chance to service the car as most of the rubbish has to be removed to get into some places.
Marka
22
Sep 11, 2016 12:09 AM
oldjaglover
Sep 29, 2015 03:27 PM
reb1999
Sep 26, 2015 08:41 AM
krhaskin
Sep 24, 2015 08:14 PM
