Facelift Oil Analysis
Old Aug 31, 2016 | 12:00 PM
plums's Avatar
Originally Posted by ptjs1
So it seems Dealers have some latitude as long as the oil meets the defined spec.
As do all owners. Owners can even choose to exceed spec.
Old Aug 31, 2016 | 12:07 PM
plums's Avatar
Originally Posted by Vee
Not at all, Paul! I find your piece of the discussion relevant and interesting. Thanks for posting!
As for spending the money on more oil changes, instead of Blackstone, you are probably right about that Plums, I'm going to do it one more time, after the recommended 4,000 mile mark, just to see what happens.
I used to use 15w50 for my spring oil change and back to the 0w40 for the fall change, I may reconsider that, or hell with it, if I'm going back to 3,000 mile interval oil changes, I'll stick with the cheaper stuff altogether and ditch synthetic.
I'm sort of conflicted about that.
I like to view blackstone results so long as someone else pays for it
Was there an explanation for the lead content?
In Arlington, 15W40 would do you fine. And Shell Rotella has got to be one of the
best and cheapest in that category. Yes, it *is* API rated for spark engines.
You might like Shell Rotella T6 0W40 full synthetic out to 6000 miles, although
5000 miles is a lot easier to track on the odometer.
Both of the above have better HTHS numbers than even guaranteed by
ACEA A3/B4 which stipulates a minimum of 3.5
Old Aug 31, 2016 | 01:03 PM
95 Cat's Avatar
I just did my first oil change in this car. Used regular (non synthetic) 10-40. Will change again in 3000 miles.
Old Sep 2, 2016 | 10:37 AM
XJSFan's Avatar
Originally Posted by XJSFan
I decided to change from Mobil 1 0W40 and try a OCI with Maxlife semi syn 10W40... No reason for the change but just decided to try something different.
I did the oil change yesterday with Maxlife 10W40 and am happy with the results. The V12 was very smooth, quiet and responded well on the 30 mile drive after the change. Cost was $17 per 5 quart container and I needed two of them. The temp gauge actually was slightly lower during the drive then when I was using Mobil 1 0W40. Running a little cooler is always good for our V12's. LOL...
Old Sep 2, 2016 | 11:03 AM
Mikey's Avatar
I hope you're not attributing any of this to the oil change........
Old Sep 3, 2016 | 09:16 AM
XJSFan's Avatar
I have owned dozens of vehicles, including many collector cars, to know when I feel or hear a difference, good or bad... Most likely, it was just from having fresh oil and a slightly cooler outside temps that made the car perform great. I really do believe Maxlife 10W40 is a good match for the XJS V12.
Old Dec 20, 2016 | 09:40 AM
Vee's Avatar
Vee
I have an update.
I changed the oil out, at 4,055 miles. The report came back better than the last one.
Conclusion?: If you're using Mobil1 0w40, it seems to make sense to change the oil every 4,000 miles.
I've since switched to Castrol Edge 0w40. Not sure I'll be running another one of these tests though. I think I got what I came for.
Old Dec 20, 2016 | 10:08 AM
  #28
Mikey's Avatar
If you're going to change oil at 4K miles interval, don't bother with synthetics and don't bother with sample analysis.
Old Dec 20, 2016 | 10:21 AM
Vee's Avatar
Vee
Yes, it would certainly seem to be the case. The premium cost for some synthetics are now minimal. I managed to order two 5 quart jugs of Castrol Edge 0w40 for just a few cents over $20 each. Even conventional oil does not get much lower than that!
I do think I'm done with the sample game though. I may run one more now that I have switched to Castrol Edge, to see if there's any difference.
Old Dec 20, 2016 | 11:20 AM
  #30
Ezrider's Avatar
i think you are accually missing somthing.
universal averages are based on 4000k miles. so there for you run your oil longer you will show higher wear metals because it has been in the engine longer. the tbn is still strong so no need to change early.
the 4k mile check was just to make sure that you fall in the averages at that millage. you can continue to change at 7500 and use your first sample as your averages. if it really worries you consider a 4k mile oil filter change without draining your oil.
Old Dec 21, 2016 | 07:47 AM
  #31
Vee's Avatar
Vee
Thank you for putting that into perspective! Makes sense.
al_roethlisberger
Jul 16, 2024 04:19 PM
xjsman89
Apr 13, 2016 12:52 AM
Larry-Cleveland
Apr 1, 2016 05:54 AM
Terry007
Mar 25, 2016 09:23 PM
Jan 9, 2012 11:34 PM
