Failed Ontario Etest again
Old Oct 15, 2013 | 08:05 PM
Gunner01's Avatar
Default Failed Ontario Etest again
I've had the Jag (1990 V12) in twice now with 2 fails.
Here in Ontario Canada, a car the is older than 1996 is tested at idle and again at about 2500 rpm with sniffers in the exhaust.
First attempt passed the high rpm
HC limit =200 test =136 pass
CO limit =1 test =.67 pass
First attempt failed idle
HC limit =200 test =412 FAIL
CO limit =1 test =.69 pass
Then I changed air filters, oil filter, oil, sparkplugs, wires, cap and rotor
Second test passed high rpm
HC limit =200 test =149 pass
CO limit =1 test =.87 pass
Second attempt idle
HC limit =200 test =225 FAIL
CO limit =1 test =.81 pass
What do these numbers suggest to you?
converters,o2 sensors vacuum.
Any ideas to squeek it by this time, maybe a fuel additive, or some other trick.
Just want to put a few miles on it before winter comes and I take it apart for a paint job and other maintenance.
Thanks for your help
Old Oct 15, 2013 | 09:04 PM
Scoupe89's Avatar
I would use E85 blended gas to breeze through emissions.
Ethanol will burn cleaner and only a few gallons should be needed!
Easy fix versus O2 sensors and cats.
Old Oct 15, 2013 | 09:23 PM
Mikey's Avatar
E85 is all but unavailable in Ontario (thankfully).
Did you mean to say E10 (10% ethanol) or meant E85 (85% ethanol).
I'm not sure the car would run on E85 even if it was available.
Old Oct 15, 2013 | 09:39 PM
Scoupe89's Avatar
You are so close E10 blended at 20-30% should get you through.
I would not run straight E85 as some non SS lines could be effected.
I have a flexfuel truck that runs on E85 and the fuel lines and fuel filter are larger. I also use about 15-20% more fuel. Not a bargain!
Old Oct 16, 2013 | 07:37 AM
Gunner01's Avatar
Thanks for the ethanol ideas, I'm looking for my local supplier. I will report back with results, i'm sure they will be positive
Old Oct 16, 2013 | 07:46 AM
pitifulpluto's Avatar
I think your catalytic converters may be dirty.
There is an old trick you can try which is to add a little lacquer thinner to your gas and then do about 150 miles to clean out your cats.
Another thing which is great, get the aerosol sea foam that will clean things up. However your car will smoke A LOT from the exhaust for about 20 minutes. Sea foam claims to clean cats. I don't know if this is true but it sure does clean your intake and valves.
Good luck passing emissions.
Old Oct 16, 2013 | 09:03 AM
At that age my guess would point to 02 sensors failing, certainly worth considering checking at least.
check Terraclean as a possible way to help reduce emmissions
By all means watch the while video, but the part you're really interested in comes in at around 6 mins 30 secs
https://www.jaguarforums.com/forum/x...ght=terraclean
TerraClean
Old Oct 16, 2013 | 12:10 PM
Gunner01's Avatar
Ha Ha! just got back from Canadian Tire (auto parts store) picked up a couple cans of SEA FOAM.
Tonight I will give it the treatment. I also picked up a gallon of ethanol, I will add it to 5 gallons of gas and see what the results are.
Old Oct 16, 2013 | 12:42 PM
Mikey's Avatar
Gunner- there's a very good chance that the gas you're using is already 10% ethanol.
Old Oct 16, 2013 | 03:01 PM
Vee's Avatar
Vee
Buy CRC Guaranteed to Pass® Emissions Test Formula 05063 at Advance Auto Parts
There's also this product called "Guaranteed to Pass" which may work for you as well?
Old Oct 17, 2013 | 03:57 PM
Gunner01's Avatar
Second attempt idle
Yay! I passed
Third try idle test results
HC limit =200 test =200 pass
CO limit =1 test =.29 pass
I ran 2 cans of SEA FOAM through the intake while running the engine and I added 1 gallon of ethonal to five gallons of the highest octane I could get 94
Now I can drive it for a few weeks before the snow comes
Old Oct 17, 2013 | 08:52 PM
Mikey's Avatar
Good news!
Old Oct 18, 2013 | 07:09 AM
AllanG's Avatar
Gunner,
Glad she passed the test
In the future, one thing that you might try which is a lot cheaper and a lot more fun, is to do an Italian tune up.
Right before you take the test, ensure your petrol tank is less than a quarter full and pour in a 20 oz bottle (or more) of a cleaner like Techron. After warming the engine up, take it on the motorway at speed and use a lower gear to keep the rpms high, at least 5000rpm. Run the car like that for at least 20-30 minutes then go straight to the testing place.
You will be surprised how often that does the trick and it's always a pleasure to hear the engine wail
Cheers,
Allan
Old Oct 18, 2013 | 10:38 AM
Scoupe89's Avatar
Good News! Much cheaper than cats & O2 sensors. Most of our cars are not driven hard enough or often enough to heat the cats up burn the residues out of it.
Old Oct 18, 2013 | 11:38 AM
Gunner01's Avatar
Originally Posted by AllanG
Gunner,
Cheers,
Allan
That likely would have worked, the last owner stated the car was in storage the last 4-5 years and he would occasionally run it in the garage.
So it's very likely the car could use a real good highway run "Itailian tune up"
Thanks for all the suggestions, I will use them in 2 years
aode06
Jul 28, 2023 02:26 PM
NS2000XKR
Jan 1, 2017 10:41 AM
sg997tt
Oct 9, 2015 10:57 PM
Spazzzzzzzzzy
Oct 4, 2015 05:37 PM
sg997tt
Canada
Sep 27, 2015 02:40 PM
