FPR connection
Old Jul 10, 2017 | 11:51 AM
JigJag's Avatar
Default FPR connection
Can anyone tell me the B bank tuel pressure regulator connections size, thread?
Im ordering an adjustable FPR and would like to get appropriate connectors to mate with the rail exit line.
Old Jul 12, 2017 | 12:10 AM
VancouverXJ6's Avatar
I also need this info and my car is in the shop so I can't find out for myself, what pressure(s) do you intend to use and why? I've wondered if upping the pressure abit would help.
Old Jul 12, 2017 | 06:18 AM
JigJag's Avatar
I located my old OEM FPR. I'll be taking it to the hardware store today and I'll let you know the fitting size.
Ill be using the the new FPR to reduce my fuel pressure. The Bosch replacement I have runs higher than spec which was discussed at length and determined to be 36.25 psi without vacuum reference.
Adjusting my ECU idle WAY leaner has improved a poor idle that nothing else I've done could help. I'm hopeful that correcting fuel pressures downward will allow a normal idle adj setting and even better idle quality.
What issue are you trying to address that you feel more pressure may help?
