Front wheel bearings size
Old Feb 20, 2020 | 12:33 PM
Asdrewq's Avatar
Default Front wheel bearings size
I've had a problem finding decent brand front wheel bearings recently - I ordered some from a Jaguar parts supplier but they were a brand i'd never heard of.
Finally found a bearing supplier who can provide Timken for a reasonable price - Can anyone confirm that these are the correct size for the front wheel outer/inner respectively?
LM12749/LM12710 Timken Tapered Roller Bearing 0.8656x1.7810x0.61 inch (LM12749/LM12710 Timken)
L68149/L68110 Timken Tapered Roller Bearing 1.3775x2.3280x0.6250 inch (L68149/L68110 Timken)
Old Feb 21, 2020 | 02:53 AM
That's exactly what I have used for many years.
Those numbers match what I read off my XJS waaaay back.
I ONLY use Timken.
Old Feb 21, 2020 | 04:36 AM
ptjs1's Avatar
Asdrewq,
Just to let you know that inners and outers can still be purchased from Jaguar - about £21 each.
Paul
Old Feb 21, 2020 | 09:39 AM
Jagboi64's Avatar
Koyo is the brand that were used in the differential on my 94. Timkin is good too, but I wouldn't bother buying them from Jaguar, go to an industrial supply/bearing house and you'll probably get much better prices. I can see the Timkins for around £4 a set.
Old Mar 3, 2020 | 01:52 PM
Asdrewq's Avatar
For future reference I got them from Bearing King in the UK: https://www.bearing-king.co.uk/ for £43 including postage, so a fair bit cheaper than direct form Jaguar.
Unlike with a kit, you obviously need to get your own split pin & the correct rear oil seals depending on if you have ABS or not.
DucatiJosh
Jan 12, 2017 10:10 AM
RidenXj8
Mar 13, 2013 09:38 PM
EZDriver
Aug 25, 2012 03:30 PM
