Fuel Line adivice
Old May 20, 2021 | 08:04 PM
DonHester's Avatar
Default Fuel Line adivice
Hello all,
I am a newbie to Jaguar. I purchased a 1995 XJS convertible with 95k miles; it was a emotional decision, I just hated seeing a such a fine automobile wasting away in someone's backyard. The car has been sitting awhile, fuel turned to vinegar and the tank rusted inside. I purchased a NOS tank and fuel pump. When I attempted to remove the old tank, I crawled under the car and cut the fuel lines about 18 inches from the tank, as you see in the picture. I assumed I could find a replaceable part. Newbie mistake, big time. I can't find replacement fuel lines anywhere and I don't have the knowledge to make a replacement. Can anyone provide me recommendations?
Thanks,
Don
Old May 20, 2021 | 09:13 PM
Thorsen's Avatar
Looking at the first picture - did you accidently cut into the body?
I don't have my face-lifted XJS any more so I can't go outside and look, but I don't think the problem is as bad as you think it is. You cut the braided fuel lines in half but you probably needed to replace them anyway. Check out this thread for how to remove the collar on the old crimped-on hose fittings. You're working with fuel lines here so make sure you remove them from the car and clean them thoroughly before trying to cut the collar. Even old fuel burns quicky
Old May 20, 2021 | 10:59 PM
DonHester's Avatar
Hi Thorsen,
Yes, I cut into the body. An unforced error I’ll need correct. I fortunately have the welding tools and skills to fix that problem. Thanks for the reference to the thread. I now can see a way forward out of this predicament without causing further damage to the car.
Don
Darrenmb
Feb 5, 2021 07:34 PM
bullittandy
Jul 27, 2015 04:58 PM
Woznaldo
Jun 4, 2013 05:48 AM
calvindoesntknow
Aug 28, 2012 03:34 PM
Jag_Generation
Apr 29, 2012 12:10 PM
