Fuel line sizes
Old 03-14-2016, 06:26 AM
daverb's Avatar
Default Fuel line sizes
I am sure someone has replaced the fuel lines for the fuel tank, does anyone remember the sizes. I want to do mine and would like to have them so I have them on hand.
Thanks ahead of time
Dave
Old 03-14-2016, 07:03 AM
Received 10,348 Likes on 6,845 Posts
Memory.
The large from the main tank to teh sump tank is 1/2" (12.5mm)
The large from the sump tank to the pump inlet is the same size.
The high pressure from the pump to the elbow in the floor is 5/16" (7.5-8.0mm).
The return in the LH corner is 10mm.
The others floating around are 8mm.
The 2 on top of the cradle, outside the boot, are 8mm, and should be included, coz many a fuel smell in an XJ-S is traced eventually to those 2 suckers.
The vent hoses at the top RH corner and up into the buttress, NO idea, I removed them and did away with that stuff, and vented the tank to the outside.
All those hoses except the HIGH pressure hose are standard fuel rated hose, BUT, I use EFI spec on all of them except the 1/2" gravity hoses, where I use standard fuel rated hose.
daverb (03-14-2016)
Old 03-14-2016, 07:51 AM
daverb's Avatar
Originally Posted by Grant Francis
Memory.
Hey thanks Grant, was hoping you get this info to me, have a great day
Grant Francis (03-14-2016)
Old 07-16-2022, 12:19 AM
Nair's Avatar
Default Bumping up a older thread
Dave
Just curious if you have replaced all the hoses including injectors ? I am working on a similar project now.
Doomer
09-03-2018 07:03 PM
jaguarguy13
XJ40 ( XJ81 )
05-01-2016 10:43 PM
Asdrewq
04-30-2016 11:53 PM
ahunt4
04-15-2015 04:48 AM
Matt300ZXT
10-21-2012 11:36 PM
Quick Reply: Fuel line sizes
