Headlight Problem
Old Oct 10, 2011 | 08:54 AM
92XJS's Avatar
Default Headlight Problem
I have a 92 XJS V12 and my headlights are always on I had to disconect the battery so it wouldn't die. Even if the switch is in the off position the headlights stay on and they stay on in every other spot on the switch. All the other lights on the car work as well. Any help is appreciated. Thanks
Old Oct 10, 2011 | 03:27 PM
warrjon's Avatar
First thing to do is check the headlight relay is not stuck on. The headlight switch operates a relay it does not operate the lights directly.
here is a link to the elecrical guide for the MY92 http://www.captainjaguarscathouse.co...ec%20Guide.pdf
Old Oct 15, 2011 | 09:14 AM
92XJS's Avatar
I put a new headlight relay in and the headlights stayed of for about an hour and a half then came back on and wouldn't stay off so I had to disconnect batt again. Any other ideas? Thanks
Old Oct 15, 2011 | 04:46 PM
warrjon's Avatar
Disconnect the power wire from the relay to the headlight the headlight should go out. Reconnect this wire and then disconnect the power from the light switch to the relay (this is the wire that makes the replay activate). Post the results.
I would also check the wiring around the area if there is something amiss when you disturbed the wires give them all a good rattle.
99xk8guy
May 28, 2024 09:36 PM
afterburner1
Dec 16, 2015 12:12 AM
avern1
Sep 8, 2015 06:25 PM
mcdutch
Sep 4, 2015 03:38 AM
laserguy
Sep 3, 2015 02:02 PM
